Which fan controller for Coolermaster Wavemaster?
2 May 2004
Hi,
Been looking at some fan controllers for my Coolermaster Wavemaster.
Found this:
http://www.overclockers.co.uk/acatalog/Silverstone_Control_Units.html (top one)
and this:
http://www.overclockers.co.uk/acatalog/LianLi_Control_Units.html (top one)
The silverstone looks more advanced and looks like it shows a lot more but it doesn't actually say how many fans it'll control.
Which out of these two should I be getting? Also, how many fans does the Silverstone cool?
Please say if there are any better fan controllers that'll fit in my case :)
EDIT
The fan controller has to control atleast 3 fans, more if possible but 3 is fine. :)
Craig.
rich99million said:
http://www.silverstonetek.com/products-fp52.htm
Maximum output for one channel – 0.8amp (9.6W)
Maximum combined output for all three channels – 1.5amp (18W)
Ah, cool, so three fans. Thanks rich99million :)
EDIT
I prefer the Silverstone, is it actually best out of the two I posted above?
EDIT
Also, for the heat sensor on the front of it, how does that work? Does it come with a heat sensor pad thingy that I stick onto whatever I want to monitor?
EDIT
Just noticed it comes with HDD LED, Power LED and stuff. Do I have to choose between having the HDD LED on the fan controller or on the front of the case?
Thanks.
