I am building up my watercooling setup bit by bit as it is taking me ages to decide on which parts to go for and what overall budget i want to set.
I have the case already, Corsair Air 540.
I want a fan controller which will enable me to control 5 fans which will be on my 240+360 rads.
I might mix the two on the 240 and use the fith channel to control my rear exhaust fan if i decide it's too audible.
I looked through the ocuk selection and to be honest there wasn't anything that made me want to get my wallet out. The BitFenix Hydra Fan/LED Controller looks alright and simple enough to use, and some of the manual dial ones were ok. Not sure how i feel about the touch screen ones, look more prone to failing.
Anyway, just wondered what you guys/girls are using and if you have any recommendations.
