Ive got a Coolermaster Hyper 6 and want to quiten it down now thinking of one the following fans
SilenX 80mm 9 dBA Fan
Input: 12V/1.08W
Speed: 1300 RPM
Air Flow: 18 CFM
Noise Level: 9 dBA
Three Pin Connector with Speed Monitoring
SilenX 80mm 14 dBA Fan
Input: 12V/1.08W
Speed: 1800 RPM
Air Flow: 28 CFM
Noise Level: 14 dBA
SilenX 80mm 15mm Depth (Slim) Fan
Input: 12V/0.96W
Speed: 1900 RPM
Air Flow: 24 CFM
Noise Level: 14 dBA
SilenX 80mm Thermistor Fan
Input: 12V/1.2W
Speed: 1400-2400 RPM
Air Flow: 18-28 CFM
Noise Level: 11.8-14.4 dBA
Three Pin Connector (Supports RPM monitoring
atm fancy the 9db fan but will that push enough air for the hyper ? and also any advice , tips or alternates wlecomed
cheers dave
Input: 12V/1.08W
Speed: 1300 RPM
Air Flow: 18 CFM
Noise Level: 9 dBA
Input: 12V/1.08W
Speed: 1800 RPM
Air Flow: 28 CFM
Noise Level: 14 dBA
Input: 12V/0.96W
Speed: 1900 RPM
Air Flow: 24 CFM
Noise Level: 14 dBA
Input: 12V/1.2W
Air Flow: 18-28 CFM
cheers dave
