Which fan(s) to use ? Want peace and quiet
  • Thread starter Thread starter Seirrah
  • Start date Start date
Seirrah
S
Seirrah
I'm currently messing about with my pc in order to lower it's volume.
I've got my Zalman flower on the slowest speed that the variable resistor will allow.
I previously used four case fans and I've recently been using just the two, and input past my hard-drives, and an exhaust below my psu.
I think I may need to just remove one of these fans, as lowering the CPU fans speed didn't help too much. If I was to remove one fan would it be best to remove the front fan or the exhaust ? ...or does it not matter one bit.
Any other suggestions to improve the noise is most welcome!
Thanks
Ill tell you what i did.
Bought 2x 120mm Akasa Ambers (Ultra Quiets) 2x 80mm Akasa Amber (Ultra Quiets)
And a Fan Controller!
Now my system is very quiet! The Fan Controller is very handy!
