Which fan would you pick?
4 Sep 2011
Need some help please in choosing one. I require a fan for the front of my NZXT Phantom Enthusiast and I don't know what's best.
This is my first build and I'm struggling to say the least :(
Due to the fact I can't fit a side 200mm fan (K2 Mount Doom cooler would clash) I am thinking I need a really good intake fan at the front that's capable of shifting lots of air.
I'm currently looking at these fans:
YOUR BASKET
1 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £14.98
1 x BitFenix Spectre PRO 140mm Blue LED - Black £13.99
1 x Corsair SP120 Performance Series High Pressure - Single Pack £13.99
1 x NZXT FZ-140 Airflow Fan Series, Blue LED - 140mm £12.98
1 x Akasa 120mm Piranha high performance PWM air ripper blade fan £12.00
Total : £76.64 (includes shipping : £7.25).
The NZXT & BitFenix fans have been added on the basis that they offer the LED facility and I thought this would look nice to accompany the top LED fans. However, this is not something I absolutely must have.
I intend to keep all the other fans (for the time being) as the supplied NZXT variants.
So, which one would you pick and why?
Thanks
What other fans are you running? (in partic. are you running the 2 side fans; sucking cool air over the hd's)
and set up as intake or exhaust ?
Keep it simple - try without a front fan and see what temps you get
then fit 'any' spare 120/140m fan that you have to see what if any difference it makes.
If it is a lot better then buy a good quality fan for, hopefully , even better results.
I've never been sure wether the front fan is such a good idea given the fact that it is intended to pull air in and when it does it immediately hits the air being drawn in by the side fans.
I made an error in my previous post. The side fans are intakes not exhaust. It's been a long day :D
Yes I see your point regarding air colliding with the side intakes. If this is indeed the case then would you say that this is a design flaw on NZXT's part?
Mind you saying that, quite a number of cases have the same profile where side fans and front intakes are in close proximity.
