Hi there, I am purchasing a HAF 922. It comes with some fans but others are not included.
Front: 200 mm fan x 1 Red LED on / off fan x 1 / 700 RPM / 19 dBA
Top: 200 mm fan x 1 / 700 RPM / 19 dBA (can be swap to 120 mm fan x 2 )
Rear: 120 mm fan x 1 / 1200 RPM / 17 dBA
Side: 200 mm fan x 1 (not included)
Bottom: 120 / 140 mm fan x 1 (not included)
I will also be purchasing the Prolimatech Megahalems CPU cooler. This also requires an extra 120mm fan
So I need to buy:
1x 200mm fan
1x 120/140mm fan and
1x 120mm fan
I have searched around for some decent fan manufacturers. Scythe, San Ace, Kama and Yate Loon seem to be mentioned as the best. But very few, if any of them, do 200mm fans.
I found one model I really like but I can only find it from one expensive UK retailer: COOLERMASTER R4-LUS-10AR-GP STORM 200M RED LED FAN
http://www.limitedgoods.com/itemVie...ogleUK&medium=free&campaign=FroogleUK_InStock
1. Does anyone know of another UK retailer for this product? I have searched many times but to no avail.
2. Would a 140mm bottom fan be better than a 120mm bottom fan?
3. Could someone please recommend some good 120/140mm fan's?
(I'm not that bothered about noise but would kinda prefer the fan to have LED's.)
4. Do I need a fan controller? What's the benefits?
Any help or criticism would be greatly appreciated.
So I need to buy:
1x 200mm fan
1x 120mm fan
