Hi,
I am having problems with my computer switching off after a while and have worked out that it is a temperature problem. I have a 8800 GTX, 6.7QX Quad core and 850kW of power.
I am using the heatsink fan that came with the package but don't think it is up to much and also I need suggestions as to how many additional fans I should have for better circulation (and what make to go for).
The computer only switches off when running high end requirements programs amking the computer work hard, the majority of applications work fine.
My cpu temperature shows at 90C+ which seems very high.
Thanks for any help you can give.
