I've recently purchased an Antec 900, however i'm using the Zalman MFC1 Plus fan controller, and as you're probably aware, the stock Antec fans do not have the third wire to be connected to any sort of controller or monitoring hardware, and therefore i need to replace these fans.
There are 5x 120mm fans and if i'm lucky a 200mm fan which will need replacing, however im not really sure which fans to go for!
I'd like to keep the look of the case and continue by having BLUE (preferably) LED's on the fans, but they also need to be quiet, shift a lot of air, and of course be cheap!
All this to ask is a lot, and im sure i'm gonna have to sacrifice airflow over price, but if you can guide me in the right direction i'll be greatful!
Low Budget: £25
High Budget £50
Obviously i want to keep to the Low Budget, but i don't want a noisy as hell PC, or one that does not shift air (as i have stuff overclocked etc)
Oh and of course, if there's an easy way to mod the fans to allow them to work with my fan controller that would be even better, then all i have to do is get 2x 120mm fans!
Thoughts Appreciated,
Addicted
Low Budget: £25
High Budget £50
Addicted
i mean yeah, if they are high RPM fans, they won't be on full, but you know what i mean
for all fans!)
