Which flash for A700 ?
7 Nov 2002
pantyhose factory
Its got to the point where the on board flash is not really cutting it. In a few weeks time I will be doing some inside shooting at a small friends and family event, so I am in the market for a flash that will give better results than the on board but not break the bank.
The reason i am looking for a fairly cheap one is that it is unlikely to get a lot of use as most of my shots are outdoors urban, candid, architecture, landscape work and I don't do a lot of portraiture to justify shelling out several hundred quid on a flashgun. So looking to spend around 100 tops if thats possible ?
Anyone had any experience with the ones you can get from the famous highstreet shop
I would've have said YN-565 but you can't get one for Sony unfortunately. I haven't used this but iirc doesn't get bad reviews Nissin Di622. You may want to look at it more though because I haven't looked into it.
