It's entirely subjective...
The Adobe plugin will probably cover more websites, though whether you'd come across any that don't work with the other two i sincerely doubt. The other two are open source though. It also depends what you're using it for, if just Youtube then look at using HTML5 or Minitube... but as for resource usage, which probably effects you most, i haven't a clue - sorry.
