I'm not normally a fan of gamepads but have got a couple of games on the go at the moment that would probably benefit from one.
Never used a pad before on PC so was wondering what's the best, most universally compatible option?
Is it get an XBox controller, use my existing PS3 controller with motionjoy or get a dedicated PC pad?
Anyone got any particular setup that they've found works consistently well across a decent range of games? Don't want to spend more than £40 max really.
Ta.
Ta.
I've been using mine for about 4/5 years. Or are you talking about battery life?
