I will soon have my watercooling build done and my case project complete and just need some advice on what block to buy , i have a d-tek fuzion cpu block and was looking to buy a gfx card block for my 1950 pro but didnt want to shell out on a full coverage block because in a couple of months i will be buying a ati 2900 or nvidia 8800 gts so a cheaper block that cools the core only will do for now so which do you recommend out of these 2 ???
D-Tek FuZion GFX Block or Swiftech MCW60R VGA Waterblock and do you really need to use ramsink on the memory and that voltage reg thingy
Cheers mick .
??? Cheers mick .
