Which GFX card to go for
There's not a lot in the £200 bracket that will be a significant upgrade from a 960. You could get a 380 but it's only a 10-15% improvement.
I can get a 970 for £240 is it much better than the 960
How does the 970 compare to a 290x and would a 550w psu be enough
Should be fine, 42 amps on the 12v and 550 watt is more than enough to run an single 970.
This assuming you're not running a monster CPU and 10 hard drives.
I just picked up a Sapphire Vapor X 290X new for £216 , but if you can get a gtx 970 for about the same price go for it
Thanks - People were saying against it though because the VS is the cheapest PSU corsair do
The full spec will be 4690k 8gb ddr3 1tb hdd 128gb ssd
