Which GFX Card?
30 Mar 2007
On The Earth
Hi again...
I've decided on what system to get now (I think:confused:) and the only thing im having trouble on deciding on is the gfx card..
As I said in a previous post I will be doing a little video editing, photoshop and playing BF3 and MW3 at a resolution of 1920x1200..
I have been told numerous time that I will need a 2gb card so the ones im looking at would be the GTX 560ti or the ATI 6950..
What would be the best?
Cheers Guys
what is your budget?
i mean e.g if you are going to spend approx £200 on a 2gb 560ti you might as well spend that bit extra and look for a cheap 570 (which regardless of ram differecnce is just plain and simple faster card)
I dont have any experience with bf3 personally and havent seen any benchmarks comparing 1gb vs 2gb gtx 560ti so cant comment on importance of it. But my understanding with %99 of games 1gb vs 2gb will make almost no difference at all (edit: except of course at really high resolutions), although the value of card will hold for longer.
like i say it really comes down to how much money to want to/willing to spend.
i was looking at this
http://www.overclockers.co.uk/showproduct.php?prodid=GX-247-AS&groupid=701&catid=1914&subcat=1341
i mean damn that right there price/performance is really really good.
and i would be %99 confident that the performance it woudl give vs 2gb 560 would be pretty much identical
