I'm in the process of sorting out my first loop and I'm a bit unsure about what GPU block to get for my 980. I recently bought a Thermaltake RL240 kit because it was cheap, but looking at the materials it uses, I'm somewhat confused as to what GPU is ok to use with it as I've heard you're not supposed to mix metals. The CPU block uses nickel plated copper,the radiator seems to use zinc aluminium alloy and the fittings are brass, which I would've thought would count as mixing metals, but I'd also like to think Thermaltake know what they're doing.
I can acquire both of the following blocks quite cheap, so I'd prefer to use one of these if possible:
https://www.overclockers.co.uk/ek-water-blocks-ek-fc980-gtx-acetal-wc-652-ek.html
and the EK-FC980 GTX - Nickel (couldn't find it on Overclockers)
Any advice is greatly appreciated.
Thanks.
Thanks.
and because I've scrubbed coolant stains off other people's blocks before now. I'm boring and a coward....but my loop is cool & clean and my carpet only has clear, colourless stains on it
