Which GPU for me?
12 Apr 2009
Hi. I have a pretty basic computer which I'm hoping to scrap sometime and build a new one. For the time being, I need the best possible graphics card that is compatible with my PC; also to be sure I will be able to play up-coming games like MW2 & L4D2. Mianly a gaming GPU.
So, the specs:
I've looked on nvidia.com using their "Help Me Choose" option, and it shows the 9500 GT (DRR2 & DDR3), 9400 GT, 8500 GT & the 8400 GS. I just want to check with you guys if this is correct or if you recommend something else.
I currently have a 7300 LE which is ok at the moment to play Left 4 Dead and CoD4 (rarely constant 60 FPS).
Much appreciated, thanks :)
The GeForce card might not work with your system.
What is the full spec of the system and what model PSU have you got ?
CPU: Core 2 Duo 4400 @ 2.0GHz
RAM: 3GB
OS: 32-Bit Windows Vista Home Premium SP2
HDD: 1 141GB
GPU: Nvidia 7300 LE
Motherboard: Leonite2
Disk drive: Samsung HD161HJ
Model of PSU = I don't know..
