Which Graphics card is better ?
17 Jan 2007
Which of these 2 graphics cards are better & am I going to actually notice any difference ?
BFG GeForce GTS250 1GB :- http://www.bfgtech.com/bfgrgts2501024oce.aspx
INNO3D GeForce GT9800 1GB :- http://www.inno3d.com/products/graphic_card/gf9/9800gt_esave.htm
If you had one of each could you SLI them together or do they have to be identical makes etc ?
I was running a much lesser BFG card untill it blew up ! I went & bought the INNO3D as a replacement & a mate told me 2 days later that BFG operated a life time warranty so I sent it to them & the BFG GeForce GTS250 1GB was the replacement sent to me FOC , so I already own both cards but have never used the new BFG one, hence the question .
__________________
Colin
BFG is the slightly better of the two cards and is in fact a rehashed 9800GTX+. It has 128 stream processors compared to 112 of the other card and faster clocks on both core and memory. The BFG is easily the better choice of the two but I dont know if they can be SLI'd together but I suspect it might be possible.
