Which graphics card option for built pc
13 Sep 2010
Hi
I think I'm gonna go for a pc built by overclockers, so I can return to iracing. Maybe the i5 4670k scythe, but I keep holding out, hoping it will become one of the weekly deals.:p
I'm going to be running triple 1920x1200 monitors and was hoping you could tell me which card is best. I was set on a 7970 but have 2 choices, msi 7970 lightning boost or his 7970 iceQ x2. I like the fact the msi has 4 mini display ports, so I can connect all my monitor via same connection, as monitors have displayport, so I'm also hoping its the better card? Also what if I threw a gtx 780 into the mix. It's the kfa2 model. Is it worth the extra.
Thanks in advance ;)
