I must admit that my HD 6990 is way to power consuming and noisy for my little ITX machine and to what its used for - and also the Core i3 3220 may be a small bottleneck also.
So I have decided to go after at mid-range class card to max £160, since I have set myself defined and non-negotiable budget this time because usually I'm pretty bad at keeping budgets always justiying £15 for 5 FPS more or so with a better card.
I have been looking at two cards that are both just a a few quid under £160 and they are:
ASUS GeForce GTX 650 Ti Boost DirectCU II OC 2GB
CPU clock speed 1020 Mhz
Processor boost clock speed 1085 Mhz
and
eVGA GeForce GTX 650Ti Boost Superclocked 2GB
CPU clock speed 1072 Mhz
Processor boost clock speed 1137 Mhz
The card is to be using in a Cooler Master Elite 120 ITX case, so there's enough room.
I'm not sure which card I should choose ? the eVGA is the fastest but the Asus has the best cooler and slightly OC'ed also.
and
for your budget you can get a gtx 660 or 7870
