which graphics?
To be honest, I wouldn't go with either.
The HD 6990 is hot and very loud while the GTX 590 has an unfortunate tendency to melt.
Howabout a nice GTX 580 for £350? there isn't much this won't play (unless you want to play over three screens or very high resolutions). You also have the option of adding a second in SLI in the future (so long as the motherboard and PSU support it).
May I ask what the rest of your spec is what monitor resolution you will be using?
