Which Haswell to pick?
I was thinking of a new GPU and is it that much of a difference if i use a standard cooler compared to an aftermarket one?
So you won't be going Xfire then, just replacing the 7850 with a 9***/8** in the future?
Yes, the Dark rock cooler is a lot quieter and effective than the stock one. :)
What's the performance like between the 4670k and the 4770k
EDIT: Dumb mistake that. My bad, thought it said there was a 4770k i5.
I meant the performance between the i5 4670 and the i5 4670K?
