Which HD 3650 GC?
23 Apr 2004
Apart from the obvious, can someone tell me the differences between:
Asus's HD3650 256MB DDR3 card,
Sapphire's HD3650 256MB GDDR3 card, &
GeCubes HD3650 256MB GDDR3 GC.
Which one would you buy and why?
Thanks.
couldnt find specs of all of them in a quick search but the typical differences would be core clock, memory clock and type of cooling on the card.
obviously the higher the better for the core clock and mem clock, compare these to the original spec of the hd3650 from ati and you'll see how much of a factory overclock you get.
id go for the asus myself, as they usually have quality products
Not sure if I found this right, but:
Asus = GPU@ 725MHz, and Mem@ 1600MHz
Sapphire = GPU@ 725MHz, and Mem@?
GeCube = GPU@ 800MHz, and Mem@ 1GHz
All have UVD and 120 stream processing units, if this any help.
What I want is to be able to watch Blu-Ray films on PC for now with a view to being able to watch on big screen (when funds permit) later. I currently have a 19" TFT with a DVI connection to GeForce 7600GS GC. I am concerned at the connectors required for these options!! (ie. will I be able to do what I want with this GC?)
Cheers.
