3 Oct 2006 at 14:37 #1 Wiggins Wiggins Soldato Joined 14 Sep 2006 Posts 3,664 Location Dorset Apple Cake Guys, Can you help me. I am fitting 2x 250GB Seagate Drives and need 2 fans from here to keep them cool. Any Ideas would be appreciated?
3 Oct 2006 at 14:58 #2 Messiah Khan Messiah Khan Soldato Joined 1 Sep 2005 Posts 10,001 Location Scottish Highlands What case do you have? If you need 120mm fans, then the Akasa Ambers are a popular choice.
3 Oct 2006 at 15:12 #3 Wiggins Wiggins Soldato OP Joined 14 Sep 2006 Posts 3,664 Location Dorset Apple Cake messiah khan said: What case do you have? If you need 120mm fans, then the Akasa Ambers are a popular choice. Click to expand... Its a Thermaltake Swing VB6000VNS That should be big enough I reckon
3 Oct 2006 at 15:31 #4 Messiah Khan Messiah Khan Soldato Joined 1 Sep 2005 Posts 10,001 Location Scottish Highlands Yeah that case supports 120mm fans, so the ; Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan - 3 pin (FG-024-AK) http://www.overclockers.co.uk/acatalog/Akasa_Fans.html would be a good choice.
