Which of these power supplies?
I've done quite a lot of research and narrowed my choice down to one of the following series, either Tagan Piperocks, or Be Quiet! Dark Power Pro. I cannot however find direct comparison by the same review site so I can compare any of the following which is a bit of a bummer, so I am asking on here to see if anyone has found something I can't find.
The only thing that caught my eye (although I can't find the website now) is that the Be Quiet! PSU's can be unstable on the 12v rail, however I found other review sites quoting the exact opposite.
The reason I have put different versions of both the Tagan and Be Quiet! PSU's is because I am trying to find out whether there are advantages/disadvantages between the different versions (for example the Tagan 1100W is more power efficient then the Tagan 1300W).
Price is not a problem I want to get the best I can (excluding the PC Power PSU which I think is far too expensive)
System 1 (Future build):
Rough future specs:
i7/i9 OC'd to 4Ghz
2x NVIDIA 300's (use 2x 295's as current example)
high end motherboard (not sure which socket will be used by i9 so just use i7 mobo as an example)
6-12GB of DDR3
watercooling setup including 1 triple rad, 1 high end pump.
around 4-6 case fans - LED 120mm's
6-8 hard drives (including 1-2 SSD's)
2 optical drives
4 cathodes
1 PCI express sound card
card reader expansion
around 6 usb devices
Which of the following:
Tagan PipeRock TG1300-BZ 1300w Modular BZ Series Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-019-TG&groupid=701&catid=123&subcat=1100
Tagan PipeRock TG1100-BZ 1100w Modular BZ Series Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-TG&groupid=701&catid=123&subcat=1100
Be Quiet! Dark Power Pro 1000W ATX2.2 Modular SLi Compliant Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-024-BQ&groupid=701&catid=123&subcat=1083
Be Quiet! Dark Power Pro 1200W ATX2.2 Modular SLi Compliant Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-025-BQ&groupid=701&catid=123&subcat=1083
System 2 (Future build for a friend):
Same specs, but without SLI cards, watercooling, cathodes and possibly a slightly less powerful CPU.
Be Quiet! Dark Power Pro 850W ATX2.2 Modular SLi Compliant Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-BQ&groupid=701&catid=123&subcat=1083
Tagan PipeRock TG900-BZ 900w Modular BZ Series Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-TG&groupid=701&catid=123&subcat=1100
Tagan PipeRock TG800-BZ 800w Modular BZ Series Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-TG&groupid=701&catid=123&subcat=1100
Thanks everyone
Rough future specs:
i7/i9 OC'd to 4Ghz
6-12GB of DDR3
2 optical drives
4 cathodes
Thanks everyone
