which i7 2700k
20 Nov 2012
east cost Lincolnshire
hi i have had two 2700k arrive, i only ordered 1 so 1 has to go back
but the batch numbers are different, so any body on here know if i clocks better.. the numbers are 3149d303 and 3204b626
yes.... id keep the newest but i dont know how to decode intel numbers (my last intel was a DX486@66mhz lol) one starts with a 32 so my be newer but the other has a d so may be newer than a b ..they are both from coster rica
i find this http://overclockt.com/forum1/viewtopic.php?f=8&t=1887
so 3149d303 made 2011 week 49 3204b626 made 2012 week 4 just need to find out whot the d is ?????? ... A is less voltage more heat, B more voltage less heat
Location on the wafer. Last two digits are important, you want them to be less then 15.
i know the chips from the center of the wafer are the best so maybe the the i ending 03 has a better chance...........
