I've used Linux before for a bit so my knowledge on it is a little sketchy and not up to date obviously. I'm looking (not for me though) for a dumbproof distro mainly to use for web browsing.
My req are:
Stupidly easy to use
Good compatibility (will be using wifi, flash etc.)
Less configuration settings or that is available to the user the better. Or only admin has access?
Robust and secure.
My concern are viruses and malware. How immune are linux distros from it? Firewall?
Thanks
My req are:
Robust and secure.
Thanks
