- 29 Aug 2010
- Cornwall
IvyBridge i7 3770K or SandyBridge-E i7 3930K?
Looking at IvyBridge it seems it would be quite expensive for little benefit.
I think I may be sold on the SB-E setup.
Also, didn't Vega do some comparisons showing that there is a difference running 680 SLI @ PCI-e 3.0 8x and PCI-e 3.0 16x? I don't think it showed 16x being twice as fast, but it looked like there was difference. Can't find the link at the minute though...
If it's mainly for gaming then the i5 3570K would be the one to go for seeing as hyperthreading is the only difference and games don't use that either.
He did show a difference, but it was largest/most noticeable for 4-way SLI, i.e. extreme cases.
I'm going to do this don't want to spend for no reason. If I'm not overclOcking will the stock cooler be ok?
Thanks
