Which is better for overclocking?
17 Jun 2005
Cambridge, UK
Ive currently got 2 gigs of the 6400 DDR2 GeiL Ultra 4-4-4-12 stuff and they are running fine and was planning to upgrade and buy another set but have come across this 2 other offers :
G.Skill 4GB DDR2 PQ PC2-8000C5 (2x2GB) CAS5 Dual Channel Kit (F2-8000CL5D-4GBPQ)
Package : 4096MB kit (2x2GB) dual channel pack
- CAS Latency : 5-5-5-15 (PC2-8000)
- Test Voltage : 2.0-2.1 V
- Speed : DDR2 1000MHz (PC2-8000)
- Type : 240-pin DDR2
- Error Checking : Non-ECC
- Registered/Unbuffered : Unbuffered
- Quality Control : Comprehensive rigorously tested in pair at dual channel environment
- Warranty : Lifetime
and:
G.Skill 4GB DDR2 PK PC2-6400C4 (2x2GB) CAS4 Dual Channel Kit (F2-6400CL4D-4GBPK)
- CAS Latency : 4-4-4-12 (PC2-6400)
- Speed : DDR2 800MHz (PC2-6400)
What do you reckon will be best? I can always flog the GeiL ram if needed.
The higher rated ram has got worse timmings and the lower rated ram has got as good timings as my geil.
Thanks a lot
the pc 8000 would certainly give you more headroom for oc'ing. wouldn't get in the way of high fsb's if you can get that far.
jobe
