Which is better out of these 2 cases?
21 Sep 2012
What case would you recommend,
Max £150, and I prefer the more stylish look, I've heard mixed reviews for one in particular, saying stuff about dust getting in and something to do with mesh and letting dust in.
Any help would be much appreciated.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-080-NX&groupid=2362&catid=2277&subcat=
or
http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-AE&groupid=2362&catid=2226&subcat=
I know one costs more, but is that the only big difference?
Thanks
Phantom it has better air flow options, an looks less like a kids rig.
Is that the only 2 cases you have in mind?
At the minute yes :L a lot of the time I'm being reccomended basic cases, like blocks, I'm not saying there bad, I'm sure their better than some I'm going for, but I would prefer something with more, you know, style.
You have any in mind?
I'm probably going to go for this monitor, the red tint may limit my choices though.
http://www.overclockers.co.uk/showproduct.php?prodid=MO-158-SA
The phantom is the better of the two IMO but there are better mid towers about. If you are constrained to those two because of design preferences though then I would go with the phantom if you don't mind paying the extra.
Style is a matter of personal preference... evidently so with your choices :p
IMO, you'd be betting a better styled/performing case with my below options.
Dont forget, its not about the case alone, but how far you can mod them.
And the more plastic there is, the more it's likely to rattle and show its age faster.
How about
http://www.overclockers.co.uk/showproduct.php?prodid=CA-043-CS&groupid=2362&catid=2277&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-193-LL&groupid=2362&catid=2277&subcat=
