It's the command rate for the memory. 1T means it has to wait 1 clock cycle, and 2T means it has to wait 2 clock cycles.
"This BIOS feature allows you to select the delay between the assertion of the Chip Select signal till the time the memory controller starts sending commands to the memory bank. The lower the value, the sooner the memory controller can send commands out to the activated memory bank."
