Which is better.
30 Aug 2006
These two cards cost the same amount of money, by the looks of it the XFX is faster, but how much faster at stock speeds? Am i going to be able to up graphic setting on games more with the XFX?
256MB XFX 7600GT XXX, PCI-E (x16), Mem 1600 MHz, GPU 590 MHz, 12 Pipes, Dual DVI/HDTV SLi
256MB Point of View 7600 GT GPU 560 Mhz, Mem 1400 Mhz, Pipes 12 pixel / 5 vertex.
xfx xxx cards are usually clocked slightly higher, so you will probably get a couple of frames over the POV card... plus they look nice with green dvi ports and black pcb shield;)
The XFX will be marginally faster but probably won't overclock quite so well.
Personally I'd be looking at the pricing. For £117.49 you can get a 7900gs which is a better card and will beat any 7600GT as it has 20pipes instead of 12.
