6 Apr 2008 at 22:56 #1 Dicehunter Dicehunter Soldato Joined 19 Feb 2007 Posts 15,693 Location Sol This- http://www.overclockers.co.uk/showproduct.php?prodid=MY-096-OC&groupid=701&catid=8&subcat=813 Or this- http://www.overclockers.co.uk/showproduct.php?prodid=MY-110-OC&groupid=701&catid=8&subcat=817 Fixed* Last edited: 6 Apr 2008
6 Apr 2008 at 22:58 #2 jak731 jak731 Soldato Joined 17 Mar 2007 Posts 5,508 Location Plymouth if you are not ocing the ram, i say it depends on the cpu you are running. personally i will just get the pc2-6400 stuff and leave my cpu at a slower speed if the ram cant cope with the speed. it also can mean less heat too Last edited: 6 Apr 2008
7 Apr 2008 at 00:35 #3 Dicehunter Dicehunter Soldato OP Joined 19 Feb 2007 Posts 15,693 Location Sol yes but which would you personally get, regardless of heat, or cpu spec.
7 Apr 2008 at 10:41 #4 dazz25 dazz25 Associate Joined 23 Jul 2007 Posts 1,423 I'd personally go for the OCZ 4GB (2x2GB) PC2-6400C4 800MHz as this is usually enough for most overclocking. again though, it depends on CPU and overclock.
7 Apr 2008 at 10:50 #5 Tetras Tetras Man of Honour Joined 22 Jun 2006 Posts 18,569 Match the RAM to the intended overclock, otherwise it is pointless. PC2-6400 like this: http://www.overclockers.co.uk/showproduct.php?prodid=MY-092-CS&groupid=701&catid=8&subcat=813 (Corsair 2GB DDR2 XMS2-6400C5 TwinX £32.89 inc VAT) is enough for most clocks (3.6 Ghz with a Q6600). The premium you pay on the above memory gives very little in performance, money better spent elsewhere in the system.
