Which Is Better???
15 Feb 2010
Hi I have recently purchased and built a new computer with 2x HD 5770 in crossfire in,
however just before I built this I had 2 send my 9800GX2 away to be RMA, I am now getting this back tommorrow and wondered which would be better.
My System is a
Intel i7 920 @4.0ghz
6 GB DDR3
Gigabyte EX58 Extreme
64GB SSD
1.5TB HDD
Corsiar H50 CPU Cooler
Windows 7 64bit
Thanks in advance for you replies
Dude your spec is more or less exact same as mine.
I have my cpu at 3.8ghz with that board. What temps you getting and what voltages are you using for 4ghz please.
Oh and id keep the 5770's, welcome :)
Thanks for the quick replys
Deus3x My temps are around 35 - 40 idle (Depends on if i have my heating on LOL). Full load running prime95 for about 12hrs it gets to a rather toasty 70 - 75.
Voltage is set to 1.400.
It has now been running stable for about 1 week =)
