Which is better ?
16 Aug 2010
What I am best going with with ?
Two 5770 crossfired or one gtx460 oem?
I am running an i7 920 @ 2.6ghz/12 gb/
Mostly for gaming only (skyrim, mw3)
Thanks
XFire will give better performance in games that fully support it. However, if you only play MW3 and Skyrim, these are both pretty easy on the GPU, so if I were you, I would go with the single gtx460, as I understand it, it overclocks like a beast, so you should get decent fps out of it and you could always add another in SLI in the future.
