Which is faster, Nvidia Geforce 7050 PV or Ati Radeon x1050?
4 Jan 2004
¯\_(ツ)_/¯
The geforce seems to be onboard, while the radeon is a pci-e card. They seem to conflict, and I can see no way of disabling the onboard Geforce.
Is there any benefit to going for the x1050?
In the bios, to turn off the onboard if you haven't found another way, you usually can change primary graphics to 'PCI-E' or something like that.
In terms of speed, I would guess they'd be about the same.
Maybe the 1050 a bit faster due it it having its own RAM rather than sharing system RAM.
it seems an old BIOS version has causing the onboard to occasionally have priority...
I've not updated to the latest BIOS, and set the default GFX card to PCI-e, and it seems to be working properly now - cheers. :)
1st and last time using an Asrock motherboard!
erm well i suppose they could both play games from the 90s... fairly well :D
the x1050 would probably be the fastest but this card was made as a cheep solution for vista areo users i believe and in no way aimed at gaming
it's not my rig... :o A friend of mine was having problems, I was on the verge of tell him to bin the x1050, I've not heard of either model, but now it's all fixed all is good. :) I guess if he gets a 5870 then he'll see an improvement in COD4 :D
