KAZUYA said:Hi,
Which is faster!!!
7800gs agp vs x1850xt agp![]()
Cyber-Mav said:lol how dumb can you be, not only can't you read properly but your naming competitors.![]()
Your sig's too big.J.D said:Thats one slap for ShuFFz and two for Cyber-Mav.![]()
Thats what you get for being a smart @rs£.![]()
Raikiri said:And you're quoting it
Anyway, the 7800GS does exist, nobody mentioned the 7600GT. The x1850xt you're referring to is most likely the x1950pro unless you can provide a link? (no competitors etc.)
Tetras said:You sure you don't mean an X850 XT? That would be a reasonable comparison to ask for and they are around the same price (well actually X850 can be found quite a bit cheaper than the usual price of a 7800 GS).
naffa said:Your sig's too big.![]()
Cyber-Mav said:7800gs since its the only card that exists out of those two.![]()
J.D said:Sorted now. The warning that if you don't change it or you could be suspended is a bit harsh though. hehe
Hope you have fun with your new card KAZUYA. Bench it stock and bench it overclocked. Then PLEASE just play it. Don't go hunting for a better 3dmark score as it's pointless and boring.
I do all I need to do within the the first day of purchasing a card. Only if completely bored will I go back to it.
He was responding to the post where the guy tells him his sig is too big.Sorry if I don't change what
