Which is the better card?
22 Dec 2004
Southampton, UK
256MB GeForce 7300LE TV/DVI PCI-E w/LP RETAIL
Product Specifications:
Chipset NVIDIA GeForce 7300LE
Interface PCI Express x16
Video Memory 256MB
Memory Type DDR2
Memory Interface 64-bit
RAMDACs 400MHz
Engine Clock 575MHz
Memory Clock 1400MHz
Pixel Pipelines 4
Max. Resolution 2048x1536
Compatible OS Windows 2000, Windows XP, Windows Vista
DirectX Support 9.0
OpenGL Support 2.0
Connectors VGA, S-Video, DVI-I
Package Contents S-Video Lead, Driver CD, 2 x Low Profile Bracket (DVI+SVideo/VGA)
Warranty 2 Years
128MB RADEON HD 2400PRO PCI-E w/LP RETAIL
Chipset ATI Radeon HD 2400PRO
Video Memory 128MB
Memory Type GDDR2
RAMDACs 400MHz
Engine Clock 525MHz
Memory Clock 533(266*2)MHz
Compatible OS Windows 98SE, Windows ME, Windows 2000, Windows XP
DirectX Support 10.0
OpenGL Support 2.0
Package Contents 2 x Low Profile Bracket (DVI+SVideo/VGA), Driver CD, S-Video Lead
Warranty 3 Years
Special Features
Support Windows Vista
Ultra-Threaded Shader Engine
CrossFire Multi-GPU technology
Avivo Video and Display Platform
HDCP Support
256MB GeForce 8400GS PCI-E w/LP RETAIL
Chipset NVIDIA GeForce 8400GS
Video Memory 256MB
Memory Type DDR2
RAMDACs 400MHz
Engine Clock 450MHz
Memory Clock 800(400*2)MHz
Compatible OS Windows 98SE, Windows ME, Windows 2000, Windows XP, Windows Vista
OpenGL Support 2.0
Connectors VGAS-Video (HDTV)DVI-I
Package Contents Driver CD, 2 x Low Profile Bracket (DVI+SVideo/VGA), 7 Pin S-Video to HDTV (YprPb) Lead
Warranty 2 Years
Special Features
NVIDIA Lumenex Engine
NVIDIA Unified ArchitectureGigaThread Technology
NVIDIA PureVideo technology
256MB GeForce 8500GT PCI-E w/LP RETAIL
Chipset NVIDIA GeForce 8500GT
Video Memory 256MB
Memory Type DDR2
Memory Interface 128-bit
RAMDACs 400MHz
Engine Clock 450MHz
OpenGL Support 2.0
Package Contents Driver CD, 2 x Low Profile Bracket (DVI+SVideo/VGA), 7 Pin S-Video to HDTV (YprPb) Lead, DVI-I to VGA Converter
Warranty 2 Years
Special Features
Superscalar GPU architecture
Shader Model 3.0
Requirements being half height cards with low profile brackets.
The use will be in a htpc, used for internet, DVD playback, DVB-TV recording. no gaming.
Please can you grade them 1-4 with one being the best choice.
I'm assuming from a n00b point of view:
256MB GeForce 8500GT PCI-E w/LP RETAIL - best but is it over kill for my needs?
256MB GeForce 7300LE PCI-E w/LP RETAIL
Thanks
Anyone else got any opinions on which would be the best card for a htpc setup?
And so i could learn, could you give your reasons please..
