which is the better gfx for me ?
17 Feb 2004
Im looking to buy the last agp gfx card my p4 machine will see. I havent got the £££ ready for the big jump to C2D and pci-e gfx just yet so looking for a stop gap.
The choices seem to be the :
Gainward BLISS GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (AGP) - Retail - £94 inc vat
or
XFX GeForce 6800 GS 256MB GDDR3 TV-Out/DVI (AGP) - Retail - £70.50
Which is the better card? I can spend upto £100 but not over that budget.
My system is a P4 2.8ghz
Abit IC-7G MB
1gb ram
350w ps
and currently a bottom range xfx 6800 (non ultra) with the unlocked pipes but its struggling with games like battlefield 2, test drive unlimited and soon C&C3 and only really use it for web and games.
Cheers for any advice :cool:
you wouldnt notice any difference getting the 6800 as there basically the same, best to get would be the 7600 GT which i know can run BF2 maxed and C&C 3 maxed
AndyRST said:
Is there anything better than the 7600gt in the sub £100 bracket ?
If not then will order a 7600gt :cool:
7900 GS.
hold out for a few more weeks.
when 8600's come to town the 7900 GS cards will plummet in price.
RaiderX said:
i used to run it maxed with 1 gb
either you used to play in 640x480, or you liked slideshows i take it?
i had amd a64 3000, 1GB Geil, 7800GTX and i wouldnt put it on highest everything, + 2x FSAA and AF because it would absolutely cripple it.
it was bad enough turned up more than 3/4 especially when entering the map for the first time rgrggr
I have 1GB of ram and run BF2 maxxed O_o, I run it all high with 16xAF/16xQAA and supersampling with average of 50-70fps, but I do get some freezes now and again, proberbly the large amount of graphics memory is decreasing freezing due to low memory.
BF2 dont look as good on my 8800GTS than it did on my X800XTPE :(
