Which Joystick
27 Oct 2003
East Mids.
This has probably been asked a few times already but a quick search hasn't helped me.
I'm after a half decent joystick for use in bf2, I can fly the chopper quite good with a keyboard and mouse but I get the feeling I can get that bit better with a joystick but have no idea which one to go for. I remember owning a saitek jobby a few years back that was quite good plus it had a throttle thingy on it, don't know if they still do them or not.
Thanks
The best joystick i have ever used ( and i have been through a good few ) has to be the "microsoft sidewinder force feedback 2"
It rocks - one slight problem is i believe they have discontinued this line - but if you see one second hand, then its definately worth getting hold of one.
i thought the same so got a joystick for heli's but tbh i much preffered the mouse/KB setup, joystick is much better though for planes imo :p
Would I actually benefit from Force Feedback, or is it one of those things that sounds cool :D
unfortunately for BF2 you wouldnt get any benefit from the force feedback - it just sounds cool :P
but it seriously is a sweet joystick - i used to love the Saitek range until i tried it
