# Processor: Intel Core 2 Duo processor T7300 2.0GHz
# Memory:2GB
# HD Capacity: 250 Gb
# Display: 15.4"
# Graphics Card: NVIDIA GeForce 8600M GS
# Operating System: Vista Home Premium
# Optical Drive: HD-DVD
# Networking: GLAN, WiFi (N)
# Size (WxDxH): 344 (W) x 246 (D) x 37/42 (H) mm
# Weight: 3.36kg
# Full Specifications:
# Operating System: Genuine Windows Vista Home Premium
# Chipset: Mobile Mobile Intel PM965 Express Chipset
# CPU Section:
# Microprocessor Full Name:Intel Core 2 Duo processor T7300
# Microprocessor Manufacturer:Intel
# Microprocessor Speed (GHz):2.0
# L2 Cache (KB):4 Mb
# Frontside Bus (MHz):800
# Memory:
# Memory Speed (MHz):667
# Memory Type
DR2
# Memory Size (MB):2048 Mb
# Max Memory Size:4Gb
# Hard Disk Drive:
# Hard Drive Capacity (GB):250 Gb
# Hard Drive Type:S-ATA
# Optical Drive:
# Optical Drive Type:1X HD DVD drive
# Optical Drive Fitting:Built In
# Optical Drive Speed Read:24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 4X DVD-RW, 4X DVD+RW, 3X DVD-RAM, 1X HD DVD-ROM, 1X HD DVD-R, 1X HD DVD-RW, 1X HD DVD-ROM DL (double-layer), 1X HD DVD-R DL (double-layer), 1X HD DVD-RW DL (double-layer)
# Optical Drive Speed Write:16X CD-R, 10X CD-RW, 4X DVD-R, 4X DVD+R, 4X DVD-RW, 4X DVD+RW, 3X DVD-RAM, 2.4X DVD+R DL (double-layer), 2X DVD-R DL (double-layer)
# Display:
# Display Type:Acer Crystalbrite
# Diagonal Size (in):15.4"
# Resolution Format:1280 x 800
# Resolution Type:WXGA
# Graphics:
# Graphic Card Full Name:NVIDIA GeForce 8600M GS
# Memory:256Mb VRAM, with up to 1024MB
# Interfaces:
# 4 Pin i.LINK (IEEE1394), 400 Mbps:YES
# DC in:YES
# Card reader:5-in-1 card reader (SD, MMC, MS, MS PRO, xD)
# Audio out:YES
# Audio out Type:Headphone/speaker/line-out jack
# Microphone Jack:YES
# RJ-11 Direct Port (Modem):YES
# RJ-45 Direct Port (Network):YES
# USB Port (quantity):4
# VGA Connector for Monitor:YES
# Express Card Slot:YES
# Express Card Type:ExpressCard/54
# Battery:
# Battery Type:44 W 4000 mAh Li-ion battery pack (6-cell) - 2.5 hour battery life
# Connectivity
# Built-in Modem: YES, 56K ITU V.92 with PTT approval8, Wake-on-Ring ready
# Integrated Wireless LAN:YES, Intel Wireless WiFi Link 4965AGN (dual-band quad-mode 802.11a/b/g/Draft-N)
# Ethernet network:Gigabit Ethernet, Wake-on-LAN ready
# Camera: YES Crystal Eye 0.3 MP
# Multimedia:
# Intel High Definition Audio compatible:YES
# Built-in Stereo Speakers:YES
# 3D Surround
olby Digital Live
# Windows Sound System Compatible:YES
# Features:
# Special Buttons:Empowering Key, Easy-launch buttons: WLAN, Internet, email, Acer Arcade, Acer MediaTouch keys: play/pause, stop, previous, next, record keys
# Supplied Accessories
# AC Adaptor:Yes
# Battery:Yes
# Power Cord:Yes
# Warranty:1 year manufacturer warranty
