Hi Guys,
Currently undecided as to what case I'm going to buy for my rig, my rig consists of:
Core2Duo E6600 cooled with Titan Amanda (Big TEC Cooler!)
BFG 8800HTX (Big and hot!)
2x SATA HDD's
750w PSU
I currently have an Anetc 180 but since installing the TEC and the 8800GTX I'm finding that the provided air flow isn't quite adequate.
The two cases I have been looking at are as follows:
CM Stacker 832http://www.coolermaster-europe.com/...ial=RC-832&other_title=+RC-832+CM Stacker 832
This case looks quite nice and certainly has lots of room for many fans but I'm worried about the annoying rattles some people have mentioned with the 830 range as this would most definitely annoy me!
Lian-Li PC-G70
I'm a big fan of the Lian Li, having previously owned a PC70 a while back I know they are well built! My only concern here is there seems to be a lack of fans, my current Antec has 3 fans (although not possibly as well positioned) and I'm not sure its doing the best of jobs!
To summarise, I need decent air flow to keep a good ambient temperature without too much noise (and certainly no rattles!).
What are your opinions chaps and can you suggest any other large cases that would be suitable?
Thanks!
2x SATA HDD's
750w PSU
Lian-Li PC-G70
Thanks!
. I keep trying to tell people that's the smallest ATX case ever and they just don't/won't believe me. Akasa Eclipse is excellent for water cooling. It even has a hidey-hole to put the res and pump so you'll never see them. Easyrider and Pink Floyd are both set up this way, I think. There are plenty of piccies on the cases gallery.
