Simple Question I hope, Looking for the following LCD
True 8bit colour 16.7 ml PVA/MVA panel
8ms or less
Two inputs DVI and D sub
17" or 19" depending on price
Cheap under £250
First use is for image/Video editing
Second use for full on FPS
If I have to I will go for two screens one for games, one for graphics, I know where to go for a games panel a 6bit TN panel 4ms or less like the Samsung or Viewsonic, but what about my true colour 8bit 8ms panel
Thanks Phil
8ms or less
Cheap under £250
Thanks Phil
Other than that it's the Dell 1905FP, provided you can get the 8 ms version (the 20 ms version would not be suited to fast FPS games), or the Belinea 10 19 20, which are both just over your budget.
