What is the make and model of the Toshiba?
Is it full hd and NOT hd ready?
H.D ready means can accept HD input weather it be 1080 or 720
But if the T.V has a freeview HD or freesat HD tuners onboard then they are HD T.V's
Its an okay telly, which is why its cheap, they quite slow to respond to the remote, some times needing several attempts, also not great picture quality, its quite soft looking and flat.
+1 on all of that. I bought a LE40C580 for my Mum and its a great bit of kit. Filled a 1Gb usb powered HDD with HD mkv's and it plays pretty much anything also connects to my wifi network to stream.The cheaper LED screens sadly tend to have problems when it come to uneven lighting especially blooming in the corners of the set and a much darker middle, it's really annoying for me anyhow.
I'd recommend the Samsung LE40C580 as well, can be had for £399 - £449 depending on the warranty you want, and it's probably got one of the best picture qualities on sub £700 sets, it's easy to set up has internet connectivity and can play back media directly via USB or over DLNA network. Check out the thread's on the C580 range at AVFourms.![]()
Aruffel, you sound like a chav irl
Ah just hearing your different accents, your russian is quite convincing![]()
I think i was 16 when i did that, im nearly 24 now
Hi there, you may want to consider the LG 50PK250 - 50in 1080p plasma. My friend picked one of these up last week for £480 and he is well chuffed with it.
It gets a pretty good write up from AV forums and if you are mainly running content through a HDMI connected HTPC then it will be pretty great.
