Which Lense?
19 Apr 2009
Which Lens?
Hi Guys
I took my Canon 500D to the Renault World Series and only had a 15 - 55mm kit lens at the time. This was fine in the paddock and display area but when taking shots of the racing I was struggling.
I didnt have the budget to get a better lens then so I made do. My cusin how ever had a 55 - 250mm and that was a lot better.
I plan to take a lot of pictures of Model Kitcars and Motor racing (Just as a hobby not as a professional) which would be the best lens to get to cover both of these sports?
I was looking at the 55 - 250mm lens or the 70 - 300mm lens but stuck what to go for. Any help would be much appreciated.
Matt
ooops sorry, typed this post out quickly at work.
I have a end limit of £300 but dont want to go over that unless it really worth it but simulary if theres a lense which is less but does the job that will be fine.
£300 for a NEW telephoto lens, well,..that is not enough really !
Best bet is a USED lens, Tamron do a 18-250 I think, not stabilized though and apx f4.5 I think
Sigma is your next choice i.e DG 70-200 will give you a crop factor as well so that’s 112-320, again USED is your only road.
Canon do a EF 70-300 IS USM, so again crop factor comes into play, again USED lens you can get for £300.
Other than that then is cheap low telephoto lens with tele-convertor on, again it will have to be USED !
70-200mm f/4 used should be about £330-£380ish depending on condition. You'll get fast AF and a good dollop of reach at a reasonably fast aperture. Then you can always 1.4x TC if you need more.
You can buy nearly two new 55-250s for £300!
The 55-250 is one of the best value lenses around IMO, but I'm not sure if it's suited enough to your purposes f/5.6 on the long end isn't that fast... - have never done any racing shots personally.
Well i was going to look on ebay but sadly this is blocked at work :(. Instead i had a quick look on Amazon and found the Canon EF 70-300 IS USM here:
http://www.amazon.co.uk/Canon-70-30...m=A3P5ROKL5A1OLE&pf_rd_r=04YWD8DH2XWS3NZ2ZCH1
I also found the 55 - 250mm which I used on the day: http://www.amazon.co.uk/Canon-55-250mm-Telephoto-Selected-Digital/dp/B000V9D5LG/ref=pd_cp_ce_1
Now apart from the increased zoom whats the main differences and why am I paying double for the 70 - 300mm. The 55 - 250mm ive been reading is nice choice as it continues off from the kit lens.
(As you can tell im still abit new to Photography at this level. But ive had some great results from the kit lens and im now hungry for more)
Trust me here that this is a better lens than either. If you can't afford it just go for the 55-250. But if you can ignore the 70-300, go straight for this stuff. It's top notch.
Is that the one you mean:
http://www.jessops.com/online.store/products/22119/show.html
I will obvisoly look for one used just wanted to make sure Ive got the right one. I would love to get that lens as the reviews about it really recommend it.
Thats the one.
Very good lens. You could also consider the sigma 70-200mm f/2.8 (third party made, but a faster lens that will get you blurrier backgrounds - downside is that below 120mm it's softer and it's a bigger and heavier lens).
Canon 70-200 f/4L - £330 for scruffy, £360 average £400 mint.
Sigma 70-200 f/2.8EX - non-macros are older but claimed to be the sharpest sigma 70-200 - my non macro was very, very, very good (better than my current f/2.8 IS :p). I'd advise buy a non-macro just because of my personal experience, but feel free to try the macros. Some are very sharp, some are very soft. Wheras the non-macros seem very consistent in the sense that 99% of reports (including mine) say the older lenses are very sharp, hence the reason I'd advise non-macro. Scruffy (collar will be scruffy, just look at the barrel)- £370, average £415, Mint £450.
Thats the one.
I had the 70-300 Sigma macro. It's VERY soft, so I'd agree with you.
I have read the 55-250 IS is a cracking lens for the money. If getting a long reach lens, isn't it always better to get one with IS?
Not really. Depends what you shoot. IS/VR is a last resort if nothing else is feasible.
A high quality tripod however, is always worth getting.
I bought my 450d as a kit with the 55-250 included, it's capable of taking some very sharp shots and is pretty versatile, TBH for the money I think you'd be hard pressed to find better.
Close up
Fading out background
Action
If you wanted other examples 90% of the stuff on my Flickr site has been taken with the 450 & 55-250
Ive seen the 70-200mm with IS for almost double of the non IS one I was thinking of. Would I need IS (whats the plus/negatives)?
Most of my shots will be by hand shooting things as I go.
