Which LGA775 Cooler?
11 Feb 2004
Surrey, UK
I have a 6600 and the stock cooler's pretty noisy. I'm after a quiet solution - not bothered about overclocking etc, quite happy to run at stock speeds.
Just checked OCs huge selection of coolers but there's so many!
I've got a Scythe Ninja on mine. Apart from it being a bit too big (takes up a lot of case space & doesn't fit on some motherboards), it's excellent :)
I too have a Scythe Ninja and it is virtually silent. I would check the dimensions and see if it will fit the motherboard, and indeed your case!
Having said that, a Scythe Ninja might be overkill if you don't plan to OC. The Zalman and Arctic Cooling Freezer 7 are very good and also very quiet.
This is what you're after. See this review here :)
Have a look in MM, you might find yourself a bargain. The Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) is a good option for you
