- 12 Jul 2012
After having a tinker around with fans and normal cpu cooler setup i just fancy a change and giving a liquid cooler a go, the inside of the case will look a lot neater as well.
What would you recommend, suggest your own if you don't think the ones below are upto a lot, obviously the quieter the better.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-AN&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=HS-008-CS
The only thing that puts me off the Corsair H80 is ive read a lot of bad reports about them with noisy pumps and people having to RMA them back to Corsair at their own cost.
