- 1 Sep 2005
- Scottish Highlands
Right, well I was set on getting the Nikon AF-S 105mm f/2.8 Micro VR IF ED, but now im having second doubts. The other one in the running is the
SIGMA 150mm f/2.8 f2.8 Macro EX DG HSM. I know both of the will be great ,but which one should I go for? I like the 105mm, due to its length being ideal for portrait work as well, and it has VR which is always usefull. The 150mm however is probably a better length for insect macro shots, and is a bit cheaper(£420 as opposed to £450, although can be had for quite a lot cheaper if I get it from Hong Kong). Any comments on either of these lenses?
