Hey guys,
Which X1900XT 512MB card has the best noise level?
I have decided to buy either the X1900XT or the X1950 pro
The powercolor X1950 pro has very good cooling and some say it's silent.
But from reviews i hear that the powercolor 512MB X1900XT makes a lot of noise, so that's off my list if that's really true. The Sapphire is said to better in terms of the package and warranty, but i don't hear much on the cooling and also the standard ati radeon 512MB X1900XT again makes a lot of sound. Then you have the options of external cooling, but i don't want to go there.
Then from people on this forum saying that the 256MB X1900XT out does the X1950 pro which is a 512MB card by 10-20 frames per second.
So that gets me excited
But the power color X1950 pro is a single slot card where as i hear the X1900XT takes up a dual pci-e slots.
Then from reviews it says you can over clock a X1900XT to an XT-X which makes me even more excited, which makes the X1950 pro look like a total waste of money.
I know the 256MB version is about £30 cheaper but it seems that can't be overclocked into an XT-X but the X1900XT can so i am all for that.
The only last problem is that from the reviews it says that the X1900XT 512MB can't really play games smoothly avbove 1600x1200 but i read that the X1950 pro can play up to resolutions of 2560x1600 giving a decent frame rate above 40 fps. Now that is impressive, so it has that resolution edge over the X1900XT 512MB card.
So what is your final verdict,
Firstly have what i said all correct, anything i missed out?
Is there an X1900XT 512MB with good cooling, best noise level and that takes up 1 slot?
All help much appreciated
Many many thanks
Many many thanks
