Im thinking of spending muchos $$$ on a mac very soon, be moving from a 1.8ghz athlon 64 / 2GB ram / x850 xt pe.
Current rig is pretty old and struggles with pretty much everything i throw at it. Im probably looking at a Mac Pro and maybe MBP, however before i buy i intend to go and spend a decent amount of time in an apple store with a personal shopper assisting me
Problem is the closest store's to me are in Manchester (2.5 hours away) The question is do i go to the Trafford centre or the Arndale centre. Is there a difference between the two except location?
Trafford centre is on the outskirts so saves me having to get into the city centre. However if the Arndale one is significantly better for whatever reason ill make the extra effort.
Also if i decided to buy on the spot do they offer student discounts instore and if so what kind of Id do they ask for if any?
Hope you can help
.Problem is the closest store's to me are in Manchester (2.5 hours away) The question is do i go to the Trafford centre or the Arndale centre. Is there a difference between the two except location?
Hope you can help
