Which memory for 8Gb??
30 Aug 2006
I'm thinking about upgrading my memory to 8Gb (from 4Gb).
I have two choices available, both from Corsair. One set has memory timings of 5-5-5-15 and the other 5-5-5-18 and I could save myself around £45 by going for the slightly slower timings.
Would I see much difference in performance by going for the slightly slower chips???
Lol is this an e-penis extension?? :p
Lol go for the looser timings, you can probably tighten them up yourself anyway ;)
No, - but I'll ask my husband about the extension :o
Prime use is in Adobe Creative Suite 3 (mainly Photoshop and ACR work) where I am working with Gb's of raw image files at once. Here the more RAM installed, the better the program works.
I have two choices available, both from Corsair. One set has memory timings of 5-5-5-15 and the other 5-5-5-18....
No. :)
At the moment I am using Win XP x64 Pro, but I have a copy of Vista x64 Ultimate waiting for Gretag-Macbeth to get their corporate finger out and release some Vista x64 compatible drivers so that I can profile my monitor. I am a pro photographer and need a profiled monitor to fit into my colour managed workflow.
Save yourself some money and go for the looser timings (cheaper memory). I do not think you will see a difference unless your heavily benchmarking and those few extra benchmarks numbers matter!
This is a late response as I just found this thread.
In all the testing I have ever done, programs like Photoshop, Quark, AVID, et al do not benefit from lower latencies nor do they suffer from higher latencies. They do benefit from MORE RAM. Since your raw files are in the GB sizes, you should see some benefit from more RAM. The slower memory you listed is fine.
Carol I use 8GB myself on Vista 64 and for the right application it is a very worth while investment you can see how much my system uses (and no thats not Vista using 4GB+ of cache)
A strong word of caution though as mentioned by the last poster... An awful lot of motherboards are real fussy about 8GB I hope you have an Intel chipset...
Some if I remember correctly do not work with 4 x Corsair 2GB modules, I would do some research if I were you before buying anything.
Carol Steele said:
Thanks Yellowbeard, this seems to be the general consensus from folks whose opinions I trust.
You trust this lot in here? You musnt read the General Discussion forum then, with their "Spec me a girlfriend thread" and "Oh Gnoes, i burnt my toast what shall i use to scrape it" threads. :p :D
Confused question here.
When Vista first came out a lot of people bought 4GB of memory and were complaining that Vista was only seeing 3.25GB of the 4GB.
Was this only for Vista 32bit?
Can Vista 64bit see the full 8GB of memory then?
Thats due to hardware limitations of some older chipsets which 'support 4GB' but cant map I/O related stuff beyond the real memory space.
Actually, most cases were that users could see 4gb in the bios yet the OS could not utilize it all for applications. This is a limit of any 32bit OS, Linux, MAC, Windows, etc.
I know nothing about photography, so may be talking nonsense... but here goes
Carol, have you tried one of those Calibrators, to get the colours correct on your monitor, as from my understanding, that would allow you to use the standard profile, and get the colours spot on...
May i reitterate, i know nothing about photography, so dont shoot me :o
